Eldred
Greetings , i recently purchased the card in the title.
From the configurator i found out that the block i need to buy for it is this :
This block does not come along with the 8-pin flat to normal 8-pin connectors cables.
The Gaming OC and Eagle models of both the rtx 3080 and 3080ti when dissasembled have some weird flat 8-pin cables that connect to auxiliary normal 8-pin cables where u plug in your power.
I believe when installing any water block u remove that section of the card so u need to buy 8pin flat to 8pin normal one adaptors.
Can anyone confirm this? Do i also need to purchase said cables? Does Alphacool provide those cables? If not please say so in the description so people have everything they need to install the waterblock and plug the card and play.
Thanks in advance
Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 Gaming/Eagle with Backplate
but i have one very important question.This block does not come along with the 8-pin flat to normal 8-pin connectors cables.
Thanks in advance
