Help, newbie need advise on what distro and fittings to get for dual 45mm rad with push pull configration
cosmickiller
Hi all
Need advice on what kinda distro can I get for my current setup as show in the photo
My intention is to set up dual radiator push-pull configuration, no worries I will be using the Lian Li RB-001 to shift the rad so I can apply push-pull configuration.
As you see, the Corsair 6500X side fan panel can be shifted deeper almost close to the side case.
So my question is, after using dual radiator 45mm and push-pull 25mm fans, am I able to install a Alphacool Core Distro Plate 360 Right D5/DDC V.2 with fitting custom to my setup?
If possible with the mentioned setup, what fitting should I be using for hard tube?
