How thick is the Alphacool Eiswolf 2 AIO radiator with Fans? Will it fit :S ?
Thomas_S
Hi, I have measured.... and the result is: the height of the assembly (fan & radiator) is 56mm.
bjorn80
@Thomas_S
Thank you very much for the quick reply and verification :) !
Will consider changing pc case or front placement of radiator hmmmm..
br.
Bjørn
pdifolco
Member
@Thomas_S
br.
Bjørn
Or
- replace the AIO fans with slimer 15mm ones and it may fit
- get a less massive CPU cooler, one that has rad on the sides so you can remove the one closer to the front :)
Thomas_S
If the case is designed for mounting a radiator in the front, this is certainly a good solution.
pdifolco
Member
What's the case ? Not sure a 360mm rad will fit as you need some more space for reservoir and tubing/barbs
Thomas_S
The manufacturer specs explicitly allow the installation of a 360mm radiator in the front. Normally, the Eiswolf 2 AIO will also fit, including all connections.
