How to mount Eisbecher Helix Light on radiator?
Blinky
I recently purchased an eisbecher helix light 250 and want to mount it on a 360 radiator that is on the front of my case. So essentialy I want a way to screw the two plastic brackets on 120mm fan extensions.
Problem is, those brackets are sghingle screw and I cant seem to find something compatible. Do you offer something for this scenario?
Back
