Hello, I need some advice on building my new set. I have an AMD 7800x3d processor and I bought an Eisbaer Pro Aurora 280 CPU AIO kit for it. I also have an Ascrock rx 7900 xtx taichi graphics card and I want to replace the BIOS in it, which has a 3000 MHz clock, so I am planning a good water cooling. I don't know whether to buy this ready-made set https://shop.alphacool.com/shop/cpu...wolf-2-aio-360mm-rx-7900xtx/xt-taichi-phantom -mit-backplate and add one more cooler, e.g. this one: https://shop.alphacool.com/en/shop/...os-xt45-industry-hpc-series-360mm-radiator?c= 1480 and connect it in the same way as on page 4: https://download.alphacool.com/manu...Taichi_-_Phantom_with_Backplate_Manual(2).pdf . The computer case I have is a Corsair 5000x and I can fit three 360mm and one 120mm coolers in it. Please let me know what you think will be the most efficient at a reasonable price. It's best to ask for links to the store that I need. Let me remind you again, what I already have is:
amd7800x3d
rx 7900xtx taichi
eisbaer pro aurora 280 cpu aio
amd7800x3d
rx 7900xtx taichi
Thermalright AMD-ASF AM5 CPU Bending Corrector for AMD RYZEN 7000 (Black NO TF7) | eBay
Only processors with new AM5 interfaces are compatible, such as the new Ryzen 7000 series. 1 X TF7 Silicone Grease. Materoal: This CPU orthotic device has two colors: black and red. It is made of anodized sand blasting all aluminum alloy CNC precision machining, uses the original insulation...
www.ebay.co.uk
