length of cooler tubing
John Edwards
My 360 water cooler tubing is too short for my case set up. How can I lengthen the tubing to prevent sharp bends or stress on the connections. Thanks for the help.
HI,
I think you mean the Eisbaer 360. If you need longer tubes you have to replace the existing ones and refill it afterwards. For this you can use every 11/8mm tube and distilled water.
Back
