bbyBuhoUno
Hi All,
I hope this message finds you all well.
I am looking for advice for a modular build-out - I do not want to buy all at once, rather learn by adding components to a distro plate modularly. I would like to start with my GPU, a MSI 4070 ti Ventus and a distro block that fits well into the Hyte Y70 case just purchased. Here are my components -
- Hyte Y70 Case
- CableMods.com Custom Cables for cleanliness
- Intel 11900K - currently running with an NZXT Kraken AIO
- Will be swapping the AIO after the GPU
- 4 SLOT DDR4 RAM
- Radeon RTX 6600 - this will be used for a dual-booting OSX and would like to add it to the build as the last module / component.
A few questions -
1. What is ideal for radiators and fans considering this build?
2. Is it ideal to move to AMD or Intel latest gen before the build? Looking for a long-term stable system that does not require new components for a few years - if not more.
3. Any disadvantages to begin a modular build and scale up?
I am hoping to get my hands on the Core 2 components, when they are available and the 4070 ti fits my daily needs for Windows and light gaming. My main goal is to keep the components running cool over a long period of time without the need to burn through electricity because of fans and heatsinks that eat energy.
Final goals.
- A single system running Proxmox
- Windows 11 - Native passthrough for the 4070 ti.
- OSX - Native passthrough for the RTX, supported by OSX.
Any help, advice, or general ideas for components and a modular install will be a great help and truly appreciated. FYI, I would like to focus on the 4070 ti and a distro and the Hyte Y70 to begin. I suspect I need tooling, a heat gun, bending tools, et al. Please advise and thank you for any comments - I appreciate the community here and am looking forward to become a part of the forum group.
Take care and be well.
- Hyte Y70 Case
- 4 SLOT DDR4 RAM
A few questions -
Final goals.
