Missing aRGB connecting cable from Eisblock GPX-N Plexi Light
petrosgk87
Hello,
I've ordered an Eisblock GPX-N Plexi Light 2080Ti M02 from highflow.nl and they pointed me to you.
The aRGB adapter cable that was supposed to be included in the packaging to connect the RGB cable on the block to the motherboard was missing. The block works fine otherwise but I can't use the RGB. Is it possible to get a replacement cable?
Thank you.
Back
