MSI 5070ti Expert OC water block compatibility
heckcat9
Has the MSI RTX 5070ti Expert OC been verified to be incompatible or just hasn’t been tested at all yet?
It seems MSI uses the same PCB between their similar 5080 and 5070ti cards? I want to confirm the 5070ti Expert OC hasn’t been tested (or is known to be incompatible) before I pull mine apart to check the PCB. Thanks!
We have not tested the Expert OC yet. With this generation, MSI is indeed very uncreative when it comes to different PCB layouts. They use standard boards without any special features across a whole range of different models. So the chances are good.
heckcat9
That’s good news for compatibility haha. I’ll pull mine apart and post pictures of the PCB this weekend to verify.
heckcat9
@Eddy , I finally found some time to pull the cooler off. Looks pretty similar to other MSI cards. Do you all have a water block that fits this PCB?
MSI 5070 Ti 16G Expert OC (G507T-16EC)
PCB Front
PCB Back
VRMs, memory, etc all look the same height.
Stock MSI cooler and back plate
It looks almost 1:1 like the Vanguard layout. At least I can hardly spot any differences.
It’s possible the cooler with article number 10265 could fit. Based on the pictures, I don’t see any reason why it shouldn’t — but this statement is without guarantee.
heckcat9
Yeah, looks like it. 10265 is the same fit as the MSI 5080 Expert OC as well, which I believe has the same stock cooler as the 5070ti Expert OC and they all look like the same layout as the 5070ti and 5080 Vanguard.
Looks like 10265 might be a match. :)
heckcat9
I got the 10265 block. Test fit looks good. The GPU lid, memory, and VRMs chips all contact the water block.
heckcat9
Everything fits except the thermal pad for the rear VRMs is too short. Not a big deal, I ordered some soft 1mm pads to use instead.
