Need advice about my loop
AbelJemka
Hi !
Looking for advice.
I have a rig with :
- one Alphacool Eisbaer Pro Aurora 360 CPU AIO
- one Alphacool Eiswolf 2 AIO 7900XT
- one Alphacool Eisstation DC80
- one RAD Alphacool NexXxoS HPE-30 Full Copper 360mm Radiator
My case is a NZXT H9 Elite Blanc - CM-H91EW-01.
I want to know how i can organize my loop.
I see this like this :
- first Eisbaer Pro
- second HPE-30
- third Eisstation DC80
- fourth Eiswolf 2
Is that correct ?
Best regards,
Hi @AbelJemka
If you're concerned about the general order in which the components should be placed in series, it doesn't really make a big difference in terms of cooling performance. It only makes a few degrees Celsius difference at most.
If you're more concerned about the hose routing to make it look more aesthetically pleasing/organized, then I would arrange it like this, if your case allows it: Eisbaer Pro radiator on the bottom, Eisbaer Pro cooler, second HPE 30 radiator in the lid, Eiswolf 2 cooler, Eiswolf 2 radiator in the side, Eisstation DC80 on the bottom, and then again into the Eisbaer Pro radiator in the bottom.
But that depends on whether the hose lengths and the case allow it.
Best Regards
Back
