Need Help – RTX 3080 AORUS Xtreme Waterforce (coolant completely drained)
Jed_xai
I have an RTX 3080 AORUS Xtreme Waterforce, but unfortunately all the coolant from the cooling system has been drained.
I was planning to fix it by installing the Alphacool Eiswolf 2 AIO 360mm RTX 3080/3090 AORUS Master/Xtreme with backplate, but it seems to be out of stock everywhere.
Does anyone know:
  • where I could still find this kit (new or second-hand, preferably within Europe)?
  • or if there’s any compatible alternative that would work with this specific GPU model?
Thanks a lot for your help and advice! 🙏
The coolers and the AIO are end of life, they won’t be available from us anymore. Since they’ve been EOL for quite a while, I doubt you’ll still find them new anywhere. Your best bet is probably the used market. Sorry...
A compatible alternative is EK-Quantum Vector AORUS Xtreme/Master RTX 3080/3090 full-cover block (custom loop).
Bykski also makes AORUS Xtreme-compatible blocks and they’re easier to find in Europe.
Back
