Hi There,
I'm gonna build my pc with purchasing some alphacool product. And I want to get some help.
CPU: 11900K (I ordered, but not quite sure the real power consumption, I guess a little bit higher than 10900K)
Cases: Asus ROG Helios
GPU: ASUS ROG STRIX 3090 OC *2 (Vertical mount with two riser cables)
- Is there any suggestion what alphacool water cooling product combination will works for my PC? It's better I could get a full shoping list : )
- Is it possible for to mount a 420 rads in the front of Helios, meanwhile, mounting a 360 rads (alphacool product or ASUS CPU AIO) on the top of the case? Room conflict?
- Since there is no Strix 3090 AIO, do I need another pump rather than eisbaer? Or only one D5 pump could drive 1 CPU + 2 GPU?
