NEW – ES RTX 6000 Pro GPU Cooler
jannes72
Administrator
Alphacool International GmbH from Braunschweig is a pioneer in PC water cooling technology. With one of the most comprehensive product portfolios in the industry and more than 20 years of experience, Alphacool is expanding its lineup with the new ES RTX 6000 Pro Workstation / RTX 5090 Founders Edition and ES RTX 6000 Pro Server Edition – 1-Slot Design GPU coolers.
Alphacool ES RTX 6000 Pro Workstation / RTX 5090 Founders Edition
The Alphacool ES GPU water cooler for the RTX Pro 6000 Blackwell Workstation Edition is designed for performance-optimized server and workstation systems. Its compact 1.5-slot design and rear-mounted ports allow easy integration even in systems with limited space.
The top cover is made of lightweight and durable carbon, reducing weight while providing a clean and premium appearance. The cooling block features an optimized cooling channel structure and is made entirely of chrome-plated copper. This particularly robust surface reliably protects against corrosion, scratches, and mechanical stress during continuous 24/7 operation.
For additional cooling performance, the cooler features an active backplate made of chrome-plated copper with a carbon back cover. The main block and backplate are connected via an internal double-nipple system, placing the inlet and outlet on the rear side of the cooler to save space.
Nvidia RTX Pro 6000 Blackwell Workstation-Edition
Nvidia Geforce RTX 5090 Founders Edition
Alphacool ES RTX 6000 Pro Server Edition – 1-Slot Design
With the Alphacool ES 1-slot GPU water cooler for the RTX Pro 6000 Blackwell Server Edition, Alphacool offers a solution specifically designed for rack servers. The compact 1-slot design enables very high system density and is ideal for professional data center environments.
The cooler’s top cover is made from lightweight carbon, significantly reducing overall weight while providing a clean and functional appearance. The cooling block itself is made entirely from chrome-plated copper and offers high resistance to corrosion, scratches, and mechanical stress during continuous operation.
The inlet and outlet ports are positioned on the rear side of the cooler to save space. An optimized internal cooling structure efficiently dissipates heat from GPU, VRAM, and voltage regulators, while the massive copper base ensures excellent heat absorption and transfer.
Nvidia RTX Pro 6000 Blackwell Server-Edition
Nvidia RTX Pro 6000 Blackwell Max-Q Workstation-Edition
The new ES RTX 6000 Pro coolers are now available for pre-order in the Alphacool shop.
