The multi-talent from Alphacool, the Eisbaer Pro Aurora CPU AIO has received an upgrade! It is now available with the extremely powerful NexXxos HPE radiator. This improvement enables even processors with particularly large CPU cores to be cooled even more effectively. The included mounting kit allows high compatibility with all common sockets, including the new AMD AM5.
The NexXxos HPE radiator uses the same materials as the previous NexXxos models, but goes a step further technically. Due to the condensed internal structure, the number of water channels and copper fins has been increased. Thus, a larger volume of water is in direct contact with the cooling fins and the heat transfer is improved enormously. Alphacool continues to use the Rise Aurora 120mm fan. The fan, which can be controlled via PWM, is almost silent at 800 rpm, but still offers a good air throughput together with a high static pressure. The cooler as well as the fans feature digitally addressable RGB LEDs, allowing for a brilliant illumination.
As usual, all components used come from Alphacool's classic DIY water cooling range and some are even used for enterprise servers products. The Eisbaer Pro HPE Aurora 360 CPU AIO is a powerful all-in-one water cooling system that is as easy to install as an AIO, but offers the performance of a pre-assembled and pre-filled custom loop.
radiator:
- Material: copper, brass, stainless steel
- Threads: 2x G1/4"
- Fan size: 120mm
- Fin density: 18fpi
cooler & pump:
- Material: nickel plated copper, nylon, acrylic
- Pump speed: 2600rpm (+/- 10%)
- Threads: 2x G1/4“ (+ 1x Fillport G1/4“)
- Pump type: DC-LT2
fans:
- Speed: 0-2500rpm (+/- 10%)
- Connection: 4-Pin PWM
- Static pressure: 3,17mm/H₂O
- Max. air flow: 118,9m³/h
- Number of digital aRGB LEDs: 20
Intel: 115X / 1200 / 1700 / 2011 / 2011-3 / 2066 / 3647 SQUARE & NARROW / 4189
AMD: AM4 / AM5 / TR4 / sTRX4 / sWRX8 / SP3
