New Enterprise Solution! Alphacool ES Guardian 4Port Powerfan Hub
Thomas_S
Server and industrial fans have a very high power consumption due to their enormous performance. For that reason, they can usually only be connected directly to the power supply unit, since the existing connections on the standard mainboards cannot provide the necessary power. The problem is that the function of the fans cannot be checked, monitored or controlled via the motherboard. For this, Alphacool offers a smart and efficient solution to this problem with the ES Guardian 4Port Powerfan Hub.
The ES Guardian 4Port Powerfan Hub is placed at the desired position in the server case, connected to the server's power supply and connected to the mainboard via PWM cable. 4 industrial fans can be supplied with sufficient power and monitored and controlled via the BIOS. If a fan is defective, an error message can be issued by the mainboard and the problem can be quickly rectified. The Guardian Powerfan Hub also has 2 CAN bus connectors, which allow additional functions when using a CAN bus controller and the associated software.​
L x W x H120 x 38 x 18mm
Power supply (connection)2x 4-pin Molex connection via power supply unit
Supply voltage12V DC
Continuous current12A at 12V
Maximum current at 12V16A
Connection options4x 4-pin PWM fan | 1x 4-pin PWM mainboard | 2x CAN-Bus | 1x speaker
Type power supply cable4-pin Molex/LUMBERG 1614_20
Length power supply cable110mm
Type mainboard cable4-Pin PWM
Length mainboard cable400mm
Control MonitoringDIP switch (4-way on/off)
shop offer >>> Alphacool ES Guardian 4Port Powerfan Hub
