With the new Aurora Vertical GPU Mount, Alphacool now offers the possibility to install the graphics card vertically inside compatible PC cases, whether they're air or liquid cooled. In addition, the mount features 11 digitally addressable 5V RGB LEDs that create a unique, very classy looking illumination. The digital aRGB LED lighting can be controlled either with a digital RGB controller or a digital RGB capable motherboard.
Alphacool Aurora Vertical GPU mount with riser cable (>>> offer)
| Technical data | |
| Dimensions (L x W x H) | 241,5 x 133 x 72 mm |
| Material | stainless steel, acrylic |
| PCI slots required | 6 |
| LED type | 5V aRGB |
| LED connection | 3-pin JST (approx. 410 mm cable length) |
| LED quantity | 11 |
| Compatibility PCI riser cable | PCI-E 3.0 x16 |
| Length PCI riser cable | 250 mm |
| Weight | 752 g |
| Color | black |
