nvidia 1070 founders edition needs advice for aio 120 waterblock
jamesrose
greetings. i checked the GPU configurator and fit my nvidia gtx geforce 1070 founders edition into it and came up with the M01 water block. i just received a return email from support at Alphacool.com and they told me the M01 is EOL and it is impossible to manufacture a new one. i am looking for a b-ware, hpoefully in good shape or an open box situation.. the exact manufacturers numbers i am looking for are either 1 of 3 (11321) (11353) (11359). the first is water block only, second is blockw/ hoses, third is complete AIO system. i already have 120mm radiator and hoiseswfans but a 1070 water block that is for a massive card M07 (114900. i do appreciate your concern on this . if there is anything you can help me with i would be very grateful. thanks
Vanzin
Hi I am sorry that the needed water blocks are EOl and we do not produce them anymore. Maybe you can purchase one as B-Ware from our reseller Aquatuning. Alternative you can check out Ebay. Maybe someone is selling his old water block.
