Hi, i ordered 2 radiators, you may see it by checking the order.
With both of the radiators there are a problems.
1st problem that i saw was with 240mm one, the holes for the fittings are a made with not a 90 degree angle! You will see it on the foto with fitting inserted.
2nd problem with 420mm radiator, its leaking from the one of the corners. As well photos attached.
That is really embarrassing!!! Im afraid to look at the radiators which i bought six month ago.....
When I could get refunds to order a new ones or when you will send me a replacements?????!!!!! My entire build is stooped!!!
