Hi,
I'm looking to go a little bit extreme with my watercooling idea. For the moment I only focus on the AMD 6900XT reference card and at a later stadium (summer) I will add the CPU to it. The CPU is now already water cooled through Corsair AiO.
The idea is to use this combination:
- Alphacool NexXxoS XT45 Full Copper 1080mm Nova Radiator
- Alphacool NexXxoS Nova 1080 mm fan housing - Black
- Alphacool Eisbecher D5 250mm Acetal reservoir incl. 1x Alphacool Eispumpe VPP755 V.3
- Alphacool Eisblock Aurora Acryl GPX-A Radeon RX 6800/6800XT/6900XT Reference with Backplate
Where the Eisbecher D5 is going to be mounted on the Radiator fan housing.
The distance between the PC and the radiator will be around 2 to 2,5 meter. So I need enough tubing for it.
This is my shopping list:
I do have a couple of questions
1. Can the Eisbecher D5 incl Eispump be mounted on the radiator house?
2. Is one pump enough to cover the ±5 meters of tubing?
3. Do I need any screw plugs for in/outlets like the Alphacool Eiszapfen screw plug G1/4 - deep black?
4. Do I need to buy screws to mount the fans on the radiator house?
5. If you look at layout picture do I miss any fittings or are they wrong in the picture?
6. Should I place the flow and temperature indicator anywhere else?
I already did something with watercooling but that was based on AiO, so I could use some guidance in this process
1 | 1013350 | Alphacool Eisbecher D5 250mm Acetal reservoir incl. 1x Alphacool Eispumpe VPP755 V.3 |
1 | 1019925 | Alphacool ES flow and temperature indicator "HighFlow" with RPM-Signal |
1 | 1012592 | Alphacool Eiszapfen temperature sensor Plug G1/4 - Deep Black |
1 | 1018087 | Alphacool NexXxoS XT45 Full Copper 1080mm Nova Radiator |
1 | 1020417 | Alphacool Core ATX 24-Pin PSU Jumper |
1 | 1020774 | Alphacool Eisblock Aurora Acryl GPX-A Radeon RX 6800/6800XT/6900XT Reference with Backplate |
2 | 1012804 | Alphacool Eiszapfen HF quick release connector kit G3/8 inner thread with reducing nipple G1/4 - deep black |
4 | 1011159 | Alphacool Eiszapfen 13/10mm compression fitting 90° rotatable G1/4 - deep black |
2 | 1011157 | Alphacool Eiszapfen 13/10mm compression fitting G1/4 - deep black sixpack |
9 | 1020781 | Alphacool Rise Aurora 120 mm fan (120x120x25mm) |
1 | 1020195 | Alphacool NexXxoS Nova 1080 mm fan housing - Black |
3 | 1019548 | Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - Ultra Clear 3m (9,8ft) Retailbox |
