Hello,
I currently have an Eisbaer Aurora 240 and Alphacool Eiswolf 2 on my PC' custom loop (CPU, GPU, 240mm and a 360mm radiator). I'm considering adding a reservior with pump or just a reservior to the loop.
Before I buy I just have a few questions:
- For existing loop, is it ok to turn on only 1 pump (i.e. Eisbaer or Eiswolf)? Will the water flow damage the pump that's not on (because I can't remove the pump from the Eisbaer or Eiswolf)?
- If I add a reservior without pump(mainly for aesthetic purpose and easier to add a drain port), will the 2 pumps be enough, say for a 200ml reservior?
- If I add a reservior with pump, should I only use this pump or all 3 pumps?
