Replacement for Alphacool Eiswolf 2 AIO - 360mm RTX 3080 (Reference)
4bsylon
Hey!
I have been informed that the Alphacool Eiswolf 2 AIO - 360mm RTX 3080 is discontinued for my RMA. Can you please provide a recommendation on replacement parts?
Please note I already have a Alphacool Eisstation DC80 - AIO Power Unit + Alphacool Eisbaer GPX Extension Set 90° (hose and connections) that I purchased for my loop while waiting for a replacement unit for my loop. In addition I have a Alphacool Eisbaer Aurora 280 CPU - Digital RGB.
The GPU block is my primary concern (I really liked the AIO), otherwise I guess I need some fittings for the block, more hoses and a new 360 radiator (+fittings)?
Thanks!
4bsylon
Just to be sure, you still have the Eiswolf, right? And you want to convert the Eiswolf into a regular DIY cooler? For that, you’d only need a terminal that you can mount in place of the pump unit. The article numbers would be 12987, 13763, or 12965 – all of them fit the cooler. Other than that, you’ll only need coolant, since you already have everything else. You can reuse the tubing from the Eiswolf. The power unit is your reservoir with pump, and that’s all you need. It will basically be like an Eiswolf, just without the pump attached directly to the cooler.
Back
