Hi,
which thermal pads you are using is up to you. The higher the W/mK the more heat can be transferred. Original included are our 1mm Rise Ultra Soft with 7W/mK and for the backplate our 3W/mK Ultra Soft pads. The important part is that the thickness is correct.
