Hello, i asked support in some messages, but have so far, gotten no answer, hopefully someone at support will see this here aswell, anyway, i am having an issue with poor performance for my alphacool waterblock - Alphacool Eisblock Aurora Plexi GPX-A Radeon RX 5700 XT Thicc II / III - and need assisstence, my temps are not very good, my card will hit 70c edge and 90c junction, i am running a gpu only loop with a 360mm radiator, good fans at decent speed, and waterpump is a d5 that has very good flow, i should be getting much better temps, the only other issue i can think of, is that my waterblock is in reverse flow, with the water entering the 'outlet' port first, then exiting the 'inlet' , could this cause higher than normal temps? i seen atleast one other customer get recommended to use the ports as suggested, however i want to confirm if this will offer any significant temp improvement, as i will have to completely drain the loop and change the tubing runs, any help is appreciated, thanks in advance!
