RPM to flow measurement curve of ES flow and temperature indicator "HighFlow" 17558
dx9ex
I found two different data charts:
https://download.alphacool.com/manu...indicator_HighFlow_with_RPM-Signal_Manual.pdf
https://download.alphacool.com/lega...tursensor_HighFlow_mit_Tachosignal_Manual.pdf
The paper manual in my package is the second one.
Does this model have versions V1 and V2? Which one is newer? Both documents say "V.1.00-06.2020".
My circuit: DDC with reservoir --> CPU --> 280 radiator --> GPU --> 360 radiator --> flow sensor --> DDC with reservoir
I set the pump to 100% (4450 rpm) and got 625 rpm from the flow sensor.
100-110 L/h or 160-165L/h, which is correct?
