Hello all. I built a new system earlier in the year with an R9 7900x in a Corsair 4000D. The AIO is mounted in the front position with the tubes at the top. The three fans are drawing air into the case, and there is one exhaust fan at the top and one at the back of the case. PBO is enabled, but my normal usage does not put a consistent heavy load on the CPU, so I rarely have issues with thermal throttling (since the Ryzen 7xxx series is designed to hit 95c eventually). I do, however, have rather high idle temps.
Ambient temp in my office right now is 24c, and the system is idling at around 58-60c with 3-4% CPU usage. Almost any load will immediately drive the temps up into the 70s and under a sustained load will steadily climb into the 80s and then 90s. Again, that's a rare occurrence with my usage. I replaced the thermal paste once already and attempted to re-mount the block, with no changes to this behavior.
Is this expected behavior with this CPU/AIO combo? Are there steps I can take to troubleshoot or identify any potential issues?
Thanks.
Thanks.
