Hello Guys i have in plan to setup this configuration in object for this case
the best solution quality/price could by to buy an AIO
but no one with 280 mm radiator have in the bundle the
Alphacool Eisbaer LT.
I have the stance mod for the motherboard on this case and custom psu silicone cables that route on the back of MOBO
then i mandatory need
a low profile solution
please can someone confirm that the only solution is buy each single components to build my speical AIO?
second question, i need then to order the tubes and compression fittings, what do you suggest for this case?
third an last question what diffrence on 12.7/ 7.6 fittings compared with the 13/10? because for example on the 13/10 size i have the 2 options
and i don't understand the difference
tnx for help
Alphacool HF 13/10 Anschraubtülle 90° drehbar G1/4 - Deep Black
Alphacool-Anschlüsse gehen neue Wege in Form, Verarbeitung, Farbgebung, Vielfalt. Die absolute Neuerung ist ein überragender Innendurchmesser, der das Wort Highflow auch wirklich verdient! Die ersten 3 Farben, Chrome, Deep Black und...
www.alphacool.com
Alphacools Eiszapfen Anschlussserie ist die High End Ausführung der bewährten Anschlüsse! Alle Anforderungen die an einen Anschluss gestellt werden sind hier erfüllt: Highflow, Form, Verarbeitung und Farbgebung. Kompromisslosigkeit in...
www.alphacool.com
tnx for help
