Threadripper pro 5965x W/ Asus TUF 4090 In a Server case. Not cooling when laying flat.
nsomtog
Hi all,
I'm having a huge issue, my own nervousness and laziness is most likely getting in the way of a solution; however I thought it best to check here before I try a few things.
I have an Eisbaer Aurora 360 connected straight into the Gpu. Gpu exits into a DC80 extension back into the rad. For some reason cools just fine (albeit could use a seperate rad but not enough room.) More than likely im assuming I need to bleed / burp it but I'm ultimately lost.
If anyone could help it would be greatly appreciated.
cools just fine when standing up, however it needs to be put into a server rack and will be laying flat; which thermal limits and shuts down the system. seems flow just stops.
Back
