I'm trying to find a spare gasket (the opaque flat gasket that seals the bottom of the tube resevoir to the block). I can't find any information on it. It appears to be a gasket seal between the resevoir and the block it screws into. See picture.
The tube reservoir pump combo is a great setup for efficient cooling. Make sure it’s properly installed and compatible with your system for the best performance.
