waterblog Radeon vii.With eisbaer extreme pro
B Andersen
I want to know if the eis baer pro extreme will coud ceap a radeon vii coll in over clocking to gether with your Radeon 7 fullblog cower or do I need a seperate pump reservoire and radiator.Alphacool Eisblock GPX-A Plexi Light AMD Radeon VII - mit Backplate.Alphacool Eisbaer Extreme Liquid Cooler Core 280 - Black Edition .thats it or do i nead more
Hi There, yes you can run the Eisbaer with the GPU block without problems. The pump in this unit is very good and strong. What is the PCB number of your graphics card? You can find the number on the original packaging or on the front/back side of the card.
There are very good reviews from Igor who works at igorslab.de which are linked to the product page but they are only in German dude :(
Back
