Will 5090 block fit my Lian Li O11 Dynamic Evo RGB?
i have an asus 3080 oc in my o11 dynamic evo , and the 5090 is a whole lot smaller that should be not a real problem :)
edit my current one is 293mm long and the 5090 ac cooler 223mm .... that is so fucking small lol
i hope i will get a 5090 + ac cooler soon :)
no no guys I don't doubt about the length but about the width.
I can't put the card vertically mounted because there are no PCIe5 riser cable right now and I don't want to use riser cables so I would like to mount it normally, horizontally.
that waterblock is 160.8mm in width and it's huge, I doubt that most cases can fit it.
You have to measure whether it fits into the housing. We have already had wider coolers and customers had no problems with them. Only inexpensive cases, which are generally not suitable for water cooling, are narrower.
161mm is too big for most cases, even the expensive and big ones.
I measured it and I have 163mm from the point where the current GPU touches the motherboard and the glass...
This on a Lian Li O11 Dynamic Evo RGB that isn't a small case for sure and neither a cheap one and it's meant for watercooling.
161mm is too big, I would consider it for next design @Eddy
maybe its still interesting for some one, i installed my inno5090 with ac wb today and it fits without a problem, only the power cable could be have a not so ideal angle ... (but i used a wireview so i dont care xD and I made a good guess at the size :D)
What are your temperatures under load?
Does it boosts higher?
Did anyone solve this? Is there another terminal or any solution? I do not want to mount my card vertical.
Back
