Will Eisbaer pump be enough for additional 120mm radiator and GPU block?
NNguy
I bought Eisbaer Aurora 240mm AIO and want to expand it to include GPU and additional 120mm radiator.
I know that aurora 420mm has the same pump (at least according to product page), so I assume the pump would be enough to expand with about 30cm of tubes and one block. Sadly there is no GPU pump-block for my card so I have use just block.
Is Eisbaer Aurora pump enough to handle this load?
Thanks in advance!
It will run at the maximum of its capacity, but it should still work.
Back
