Hello! I've been looking for an AIO for a Ryzen chip (that has a square plate also) and I'm considering the 360mm Eisbaer Radiator AIO (the standard, non-compact). I probably looked through all the documentation I found around, including reviews, but I'm fairly new at this so I would be grateful if you could elaborate on some points:
- Is a front-mounted (front intake) setup not viable for this AIO cooler? The only thing I found in the manual says that it should be mounted above the cold-plate so that the pump can circulate the liquid properly. I was thinking of mounting it in the front so it doesn't sit above the motherboard (in case I mess something up). Is this not optimal?
- I see there's no software or mention of fan control in the manual. Is there any way of controlling fan speed? When not under load I would like the possibility of turning down the fans so the system would be a bit quieter.
- I'm just learning about liquid cooling and don't have any experience with it. Do you folks recommend any yearly maintenance? What's the scope of things I should be doing for maintenance? Can't figure out anything else than possibly filling the system with some coolant.
- Does the coolant have any expiry date, i.e. can I buy it now and use it next year? Is the Cape Kelvin liquid the recommended option also?
Thank you for your time!
