Hi and thanks for your amazing products, I really resonate with the composability and functional approach alphacool provides.
I am currently in the process of putting together a new PC with a water cooler or AIO. However, when I wanted to put in the eisbaer 420 mm, it touched the Mainboard and did not fit into the Fractal Design Define 7 case, which is compatible with 420 mm radiators (max total width 143 mm), but not with the 144 mm and not with newer mainboards that have a heatsinks at the back panel (which are of the same height as the back panel itself).
Most other brands stick to the width of 140 mm which make them compatible with basically all cases. Looking for a solution right now, but sticking to 140 mm could be beneficial and avoid such surprises ;-)
Kind regards
Kind regards
