Hello
I recently bought this aio for my rtx 3090 reference model palit (nov -20)
After mounting it I noticed the lack of a small bolt on the front of the waterblock which then allows you to tighten the screws once the backplate is installed.
Unfortunately this creates a problem of high vram temperature that reaches 100 degrees.
Is it possible to identify and buy the missing piece without having to resort to rma? (I bought from another store)
I am attaching the photos to be able to understand better.
