rintintin78
Hi,
I purchased the Alphacool Core 120mm Reservoir VPP/D5 (Article no.: 14590, EAN: 4250197145909) and I wanted to use the side drain port. I tried to install both an Alphacool HF 13/10 screw-on nozzle G1/4 and an Alphacool HF 13/10 screw-on nozzle 90° rotatable G1/4, but with both fittings, my loop failed to hold pressure. As soon as I replaced them with the stop plug, everything worked perfectly. Do you know why this happens? Is it a known issue, or is my specific unit defective?
Thank you.
Thank you.
