Vellinious
I recently purchased the 360 distro plate left side. Why the two chambers in the reservoir? It makes filling and bleeding a real pain. I would suggest drilling a couple holes in the center piece, to allow coolant to flow more evenly between the two areas of the reservoir.
The issue is, once the pump is on, it will only pull from the side that the radiator is hooked to, but not the other. It eventually equalizes, but filling and bleeding still issues. If there were "reliefs" drilled in that center divider, it would allow the coolant to flow more freely between the two chambers and make it a LOT easier to fill / bleed. OR, just remove that center divider all together...is there a reason it's there?
