Hi everyone,
I bought an Alphacool Eisbaer 360 on August 2019 for a new PC. I bought a brand new 9900K (no overclock) in a Be Quiet Dark Base Pro 900. The goal was to have a really silent PC for audio work. I never modified the watercooling system.
From 2020 and on, I never had any problem. CPU was around 65°C in full charge. Never touched it from the day I mounted it.
3 weeks ago I bought a new m2 SSD and had to lay down the case to mount it on the motherboard (Asus Prime Z390A).
Since then my CPU goes systematically up to 100°C when running heavy job.
I visually checked the pump which seems to be working fine (see videos below). The BIOS and HWINFO both report a healthy +/- 2800 rpm.
Fans are PWM controlled between 390/980 rpm. I tried full speed just in case.
I search for pinches on the tubes but with the springs around them they look fine to me.
I am puzzled, I tried to shake the whole case to see whether something like bubles could prevent fluid running but to no avail.
I thougt AIO system was a set and forget type of watercooling (sorry I am pretty new to this).
What should I do now ?
Thanks for your time.
