Alphacool Eisbaer Aurora 360 CPU - How to remove bracket
Nilo125
I installed the Alphacool Eisbaer Aurora 360 CPU - Digital RGB, on my AM4 rig.
Now, I need to dismount it and pack it for further sale.
But I am not getting dismount the AM4 bracket from the pump head.
Could you help me please?
Vanzin
This is really difficult but the easiest way would be to use a small screw driver and pried it open. You can also use two tongs and pull them apart.
Nilo125
Thank for your message.
I suggest your company to change bracket removal procedure, because if I do what you suggest I'll certainly damage the pump head.
