Hi,
I've noticed my cooler is no longer cooling as it used to. I've reseated the block and redone the thermal paste but it doesn't seem to help. I've noticed that the pipes feel cool and so does the radiator and I cannot feel any vibration from the pump. However, the motherboard monitor indicates that the pump is working. the fans do not seem to make any difference no matter what speed they are on. cpu is around 50 degrees in idle and at the moment I can't do anything with the pc as the temp just jumps really high very quickly.
Can you help?
Thanks
G
Can you help?
Thanks
G
