Alphacool Eisblock Aurora 5700XT Plexi PowerColor RedDevil Waterblock RGB issue
DigiVortX
I've been running Alphacool Eisblock Aurora 5700XT Plexi PowerColor RedDevil Waterblock since first available & purchased through Aquatuning.de. The issue I now have is regarding the D-RGB strip noticed the first LED section had unstuck slightly and now seem to have either a crack/dry joint which causes the either first LED to not work or entire strip cuts out and found issue is slight movement causes this.
Do you do replacement strips or able confirm LED strip width? As it looks thinner than the general ones i have. I dont want to RMA waterblock for this as will cost more to ship back. than just removing the block & replacing the LED strip myself. Thanks
