ProStock
I have preorder Alphacool Eisblock Aurora acetal GPX-A for the Series Rx 6000
And my card is a SAPPHIRE NITRO+ 6900 XT
I use your tool Waterblock Finder and the result is ... Article number: 11948
Alphacool Eisblock Aurora Acryl GPX-A Radeon RX 6800XT Nitro+ mit Backplate
So my question is...does the Acetal version is the same as the the Acryl Article number: 11948 and will it fit on SAPPHIRE NITRO+ 6900 XT ?
One more question can you tell me why this product 11945 is no where to be found on your webpage it's the
Alphacool Eisblock Aurora acetal GPX-A Radeon RX 6800 / 6800XT / 6900XT Reference with backplate
i know when i place my order it was preorder but can't find it
i order it from this place https://www.performance-pcs.com/wat...6900xt-reference-with-backplate-ac-11945.html
Thx for taking the time to answer my question keep up the good work AlphaCool
