Hi
I have a question about the thermal pads included with this waterblock.
On the GPU side, there is only a single strip included for each line of VRMs, but as you can see in your own product ID photo, the factory cooler includes pads on the PWMs as well. On the backplate side, because of the placement of the ICs, the single strip doesn't adequately cover all the ICs (the factory strips are wider, as well as there not being anything for the IC on the 4th side.
For comparison, the "other companies" waterblock instructions show a much greater area of IC coverage.
As I was initially missing a set of washers, I'm wondering if perhaps the wrong set of thermal pads was included in the packaging I received with my block.
Is it ok to run the card with so much less thermal pads than factory?
