Alphacool Eisblock Aurora RTX 4090 + Eisbaer Extreme Core 280
teufelskrapfen
Hello,
I own a Palit RTX 4090 GameRock OC and I want to purchase the "Alphacool Eisblock Aurora Geforce RTX 4090 GameRock"
I only have space for a 280 radiator and wanted to know if the Eisbaer Extreme Core 280 is compatible with the Alphacool Eisblock Aurora ?
Compatible yes. But you should be aware that the Eisbaer Extreme is significantly longer than a normal 280mm radiator. Have you looked at the dimensions and measured them? The Eisbaer Extreme is quite a hunk and almost as long as a 360mm radiator.
teufelskrapfen
Thank you for pointing this out, I did not realize the Eisbaer Extreme was as long as a 360mm. I'll check if my case can house it.
