Alphacool Eisblock XPX Aurora Edge Acryl switch inlet/outlet ports
Asaki
I want to have the inlet on the right side instead of the left side. However I would like to have the alphacool brand icon on the same position (bottom right). Is this possible? Thanks!
Vanzin
HI,
I am sorry but it isn´t recommend to switch the IN and OUT since it will decrease the cooling capacity and water flow by a lot. Please use the IN and OUT as shown on the water block.
Asaki
Thanks for your quick answer, and luckily I'm aware I shouldn't switch them around :)
However, is it OK to just turn the block 180 degrees?
Vanzin
HI,
you can rotate the water block as much as you want, as long the IN and OUT are connected correctly.
