Hello!
I purchased the Alphacool Eiswolf 2 AIO - 360mm RTX 3080/3090 Ventus with backplate with Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3090/3080 Ventus to cool my RTX 3080.
Installation of the AIO was easy and I encountered no issues. It does a nice job and I'm very happy with it.
I got the Eisblock Aurora GPX-N Acryl Active Backplate because I read that variant 1 connection is compatible with Alphacool Eiswolf 2 AIO, but it's unclear of how I should go about the installation, if I were to install it in the same loop.
So I need to get the same type of tubing, 2 x G1/4' to 12.7/7.6 fitting for inlet/outlet of the backplate, 2 x quick release fittings compatible with the ones that Alphacool Eiswolf 2 AIO uses and the same type of liquid. Then I need to make the connection with the tubing and the fittings and prefill the backplate with the liquid, then bleed it and finally connect it to the AIO loop through the quick release fittings.
Is this correct and if so, can you propose a list of the items that I need so I can have matching tubing/fittings and liquid?
