andreiga76
Hi,
Do you have an ETA of Alphacool Eiswolf 2 for Gigabyte RTX 4090 Master?
It has the same pcb layout as Gigabyte RTX 4090 Gaming OC.
On your compatibility pdf it says coming soon.
Also, I've seen a post on overclockers.net about issues with the waterblock from this link RTX 4090 Gigabyte Master block, there were issues about GPU die contact because of some pads.
Eiswolf 2 version will have the same waterblock? Do you recommend some testing procedure to check the pressure on GPU die?
On this link you can find his post about waterblock issues, you need to search for Aorus Master to find it.
Thank you.
Thank you.
