Hi,
I recently put together my second custom watercooling system(last one was 18 years ago so quite abit has changed).
I included the Alphacool Eiszapfen temperature sensor(Article no.: 17363) in my loop to be able to keep an eye on the water temperature and also to adjust all the fans to the sensors readings.
The sensor seems to be showing an incorrect temperature when connected to my motherboard(Z590 AORUS MASTER). Sensor idle temperature reading is 4C with 27 on the GPU(RTX 3080), 30 on the CPU(10700K) and 28 room temperature(hot summer in Sweden). Load readings are around 15C with 52 on GPU and 60 on the CPU. I have two 2-pin temp sensor connectors on my motherboard and I've tried both of them with the same result.
Anyone have an idea what's wrong?
