abcdehc
I'm using this senser for monitor the state of my PC.
But it did not work if RPM lower than 180, it will show "RPM:0".
But at the same time, the cooling system working good, it can keep 7950XCPU running under high load.
By the way, for silence, i keep my VPP655 pump working on 1500RPM.
So i want to know if this situation is normal? Should i exchange it?
