Alphacool ES Reservoir 1U DDC leaking
Crave
Hello, I recently purchased an Alphacool ES Reservoir 1U DDC from Titanrig. I ran my usual leak test using an EK leak tester and the pump/res wasn't able to hold pressure over the period of ~2hr. Even at low pressure ~0.3bar it still slowly leaks till it drops to 0.
I read on reddit and other forums that the ES Reservoir 1U DDC has a leak problem, but most of them are from a year ago. I heard that there's a revision and the leak issue is fixed. Maybe I have an old stock?
Thanks in advance!
Crave
I should add that I double-checked every G1/4 port and made sure that they are well sealed with the stop plug and the o-ring is in place. I also made sure I tighten the screws plenty.
