Alphacool VPP755 V3 pump reservoir compatibility
Vitolo
Hi.
Just wanted to know if Alphacool VPP755 V3 pumps are compatible with Koolance RP-452x2 bay reservoir.
I am interested in purchasing these revision 3 pumps, but need to know if I can install them in my reservoir. As far as I know, they have not exactly the same dimensions of the classical D5's.
Thanks in advance.
Metropolis34
Hi Vitolo,
As far we know this pump is not compatible with Monsoon and Primochill reservoirs. The pump has got the same dimensions like the 655 the only difference is that the corpus of the 755 is bit smaller and the bearing is different. I think it would fit but please contact Koolance and ask them also for their advise to be on the safe side.
moiraliles
Hi Vitolo, 8 ball pool
Thanks for the info, much appreciated!
